![]() JAg undrar vad V-SPEC står för. PÅ vissa nissan skyline finns den beteckningen med...
Tack på förhand :D
Vad slår en Jappe!!!!??? ;) TA en funderare! ;) Säg till mig när du kommit på vad som slår värdens bästa bilar!!! |
![]() Victory-Specification....
![]() ok, vad är skillnaden då?
Hälsningar Johan Supra MKIV NA - Blivande NA-T Supra MKIV Twin Turbo Targa, såld |
![]() Skillnad fårn vanliga R34-GTR
V-spec : rake air duct Front diffuser Rear carbon diffuser Active LSD ATTESA E-TS PRO Hard suspension Combination meter with compressed scale below 3,000rpm V-spec II (Difference from V-spec) Rear brake (N1 based brake caliper) Aluminum sport pedal (Axcel, Brake, Cluth) Trim colour (from gray to black) Carbon bonnet with NACA duct White repeater lense M-spec (Difference from V-specII) Leather trim with gold stitch Seat heater (Fr) Ripple-Control shock absorber Softened stabilizer Softened steering wheel (Fine-grip type) Aluminum bonnet (Option : Carbon bonnet) V-specII NUR/M-spec NUR As a *R34 skyline GT-R final edition 1,000 unit limitation sales Adoption of the ball bearing bearing metal make turbine for *N1 Adoption of *N1 private strengthening cylinder block Use of *N1 private strengthening piston + limited car private high accuracy weight balance item Use of *N1 private piston ring * Use of limited car private high accuracy weight balance connecting rod Use of *N1 private oil pump Use of *N1 private water pump Use of *N1 private exhaust manifold Use of *N1 private intercooler air hose * Limited car private color (silica breath) cylinder head cover (cam cover ?plug cover ?timing belt cover) adoption. * Adoption of model license plate of limited car private color gold * Adoption of limited car private three-dimensional rear emblem * Addition of limited car private special body color N1 (Allt annat + dettta) Adoption of the ball bearing bearing metal make turbine for *N1 Adoption of the large-sized rear brake rotor for *N1 * Addition of large-sized air-cooled engine oil cooler * Door mirror electromotive housing function less and modification to black paint * Parking brake lever from this leather make in resin make modification * This leather center console lid in resin make modification * Abolition of air conditioner * Abolition of rear wiper * Abolition of rear fog lamp * Abolition of key less entry system * Abolition of audio
Supra Mkiv 94 Manuell US SINGELTURBO |
![]() Skillnad från vanlig R33-GTR
V-Spec Difference from Standard ATTESA E-TS PRO Active LSD Hard suspension Brake air guide LM LM limited 1996.5.21 It sells as the LE man 24 hour race/lace participation commemoration car to period limited 7 end of the month * Adopting the champion blue as a private body color * Adoption of air intake attaching front bumper * Addition of hood top mall * Adoption of carbon center rear spoiler * LM private sticker N1 N1 1997.2.3 V specifications are designated as the based car Adoption of the METAL make turbine for *N1 * Wall thickness conversion of piston second land (from 4.0mm to 4.6mm) * Material modification of connecting rod bearing * Strength improvement of air inlet hose * Adoption of air cooled oil cooler * The water pump you express, - ン enlargement * Reinforcement around the cylinder block cylinder head bolt boss * It is thin width conversion of piston ring interval (the top & second: From 1.5mm to 1.2mm) * Modification of cam profile (from exhaust side overlap 0 to 5 degrees) * Setting of engine cooling hole (2 places) * Setting of bumper air guide * Abolition of bumper net * Addition of hood top mall * The carbon center ria jauntily Ra adoption Adoption of *CFRP make under cover * Abolition of rear wiper * Abolition of air conditioner 400R Main equipment REINIK 2.8 litre engine (called RB-X GT2 : 400R exclusive) Front bumper with air intake (400R exclusive) Intercooler air guide Carbon rear wing Over-fender (400R exclusive) Big side skirt Rear bumper and 400R emblem (400R exclusive) LM bonnet (carbon, 400R exclusive) Aluminium wheels (18inch LM-GT1) HID head light (400R exclusive) Titanium dual tube exhaust (400R exclusive) Double plate clutch Carbon propeller shaft (400R exclusive) Bilstein shock absorber (400R exclusive) Titanium strut tower bar Reinforced cylinder block (400R exclusive) Cylinder head (400R exclusive) 87 metal head gasket t=1.2 Piston with cooling channel (400R exclusive) Forged crank shaft (400R exclusive) Forged connecting rod (400R exclusive) N1 turbine with reinforcement actuator High flow air cleaner Stainless down pipe Low air resistance sport catalizer N1 radiator Oil cooler Sport intercooler etc.
![]() Skillnad från vanlig R32
V-Spec (Difference from Standard) Brambo brake system BBS 17inch aluminum wheel V-SpecII Just changed tires to 245/45/17 N1 * Adding the air intake to the front bumper * Addition of hood top mall * Abolition of rear wiper The abolition of *ABS * Abolition of air conditioner Abolition of *I/C grille * Adding the baffle plate for brake cooling * Headlight from projector system modification to suspicious looking 2 light systems Also the based vehicle respectively simultaneously with *V specifications 、 V specifications II sale modification From *V specifications base turbine wheel material of turbocharger from ceramics modification to metal
Våra riktiga namn!! | Jaffa | Skitsnack | 208 | 2010-09-28 22:40 |
Skillnad mellan euro spec, j-spec, us spec ? | Stefan Palm | Teknik Mkiv | 5 | 2006-10-01 18:17 |
Nu står den i garaget. | Merl | Allmänt | 25 | 2006-04-02 02:20 |
Vad står dessa för? | Defqon | Teknik Mkiv | 10 | 2005-08-04 02:45 |
Vad står BPU för?? | Anton | Teknik Mkiv | 29 | 2003-12-17 03:47 |
